Cold weather oil temps
Went for around a 45 mile ride yesterday, temp around 55 degrees. Just for the hell of it, I checked the oil temp. after I got home. Was only 150 degrees which surprised me. Thought it would be higher. Riding in below 40 degrees temp I would not think the oil would get hot enough to burn off moisture, etc. in the oil. Whad'you think? Ever checked yours in the winter after a ride?
Riding with fork deflectors, fork baffle, and vents closed on the lowers, mine will get to about 190 degrees after a 45 mile ride in 40 degree temps.
Took my 06 Deuce out for about 40 today also, it was low 50s here and when I got back I checked the oil temp too, it was right at 150...Guess thats normal then!
It was about 70 here in West Texas and a 100+ mile ride took my oil up to about 170. Im using one of those dip stick thermometers and have never tried to check it against an accurate lab grade thermometer but I'll bet its about right. AL
It was 2 above 0 C tonight so we dressed warm and went for a 180k ride.
I have the daugs on the engine guard of my 07 softail springer, thinking the heat would rise and help keep me **** from freezing. I noticed that the heat was no where near as hot as it was this past summer, and me **** froze.![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Don't have a temp guage but I could put my hand on the oil tank and keep it there.
There is nothing you can do no matter what the temp.150 is enough to take care of the moisture as long as you ride it long enough,15 or 20 minutes minimum.
This is the same "problem" I had with my air-cooled Porsche. The winter temp never got above 176F due to the air/oil cooling in the winter.
It is important to not miss any regularly scheduled oil changes and to try to avoid taking short trips in the winter.
have no idea 50 degree weather is the dead of winter here and way to cold to ride . also has anybody heard a harley scream as it is being push out in that kind of weather the sound is horendous
