Revtech 88" Pandemonium engine
Old 10-23-2007 | 05:31 PM
Clammy's Avatar
Clammy
Default RE: Revtech 88" Pandemonium engine
ORIGINAL: cwilks
The "Pandemonium" motor IS an Evo motor with "Pan style" rocker covers and a generator style cam cover.
You sure about that? It sure looks like it's more than that to me.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old 10-23-2007 | 06:12 PM
PieceFrog's Avatar
PieceFrog
I was told Revtechs are metric motor? Can't find that info on the net. Like the Pan though..
Old 10-23-2007 | 06:21 PM
lolife's Avatar
lolife
Personally Ive never ran with a revtech............would I .................Hell yes............... . ..I have heard few negative comments about this motor............. ........ ....Ive heard alot of positive comments, about it..........Of course everbody has their opinion......and thats what makes the world go round......... ..........The warranty says it all to me................................Go for it man...............good luck on youre project and keep us posted.......(with pics)....................................LOLIFE... ..............
Old 10-24-2007 | 05:14 AM
subbycorvi's Avatar
subbycorvi
6th Gear
ORIGINAL: bfrmbama
I think SPORTSTERVILLE and subbycorvi are one and the same....
Who is SPORTSTERVILLE?? I have a Night Train '99 Evo not a Sportster.....boh
Old 10-24-2007 | 06:10 AM
subbycorvi's Avatar
subbycorvi
6th Gear
Here a list with the components used by Revtech fortheir Pandemonium 88"
Big enough to provide good power, yet still kickstart friendly. Every part was hand-picked for quality... first! Bottom to top, from the S&S® timing and idler gears to the JIMS® pinion, to the Mallory Unilite® automatic advance distributor, and back to S&S® pistons! Naturally, there is a RevTech® crankshaft with heavy-duty connecting rods working in harmony with STD® crankcases and heads. The American-made hydraulic tappets were installed in JIMS® Big Axle tappet bodies. An Andrews® cam was chosen because of it's perfectly matched design qualities for use in these 88" generator-style engines. Even the Rowe™ valve guides and Andrews® valve springs and collars, are coddling one-piece RevTech® stainless steel valves that were hand-picked for the best quality, best performance and a trouble-free combination.
Are its a good items?
Do you think that it's truly trouble-free with this spec?
Do you know if also the erly Pandemonium used a STD crankcases?
Old 10-24-2007 | 09:04 AM
cwilks's Avatar
cwilks
ORIGINAL: Clammy
ORIGINAL: cwilks
Cheers!
My bad
Old 10-24-2007 | 11:44 AM
subbycorvi's Avatar
subbycorvi
6th Gear
ORIGINAL: 4merRacer
My tech recommends revtech over others like Ultima. Granted, he says you're better off with S&S but a close 2nd is revtech. Considering how much time he has wrenching, I'd buy one.
Did your techwork onthe Pandemonium engine or similar?
Thanks
Old 10-26-2007 | 01:58 AM
subbycorvi's Avatar
subbycorvi
6th Gear
Any else comment about Pandemonium or other new panhead?......It's really appreciate.
At last I think Revtech Pandemonium has a good parts inside (STD,S&S,Andrews,Mallory,JiM's, ...) the only thinghs made by Revtech are crankshaft, valves, oil pump and I think also the cast iron cylinders.
If you look at the partsseems good, doesn't it?
Old 10-26-2007 | 02:43 AM
sgt joseph's Avatar
sgt joseph
For what its worth, revtecs are made in KOREA ! Not sure if all of em are, but i have read they are making them over there.....S&S are built in the USA.....
SnailTraX
Engine Mechanical Topics
72
10-10-2023 09:47 AM
Jebnighttrain
Custom Models
01-22-2021 07:36 AM
robinann
General Topics/Tech Tips
09-12-2012 09:21 AM
steelhorse 1971
05-24-2008 10:50 AM
subbycorvi
Custom Models
10-24-2007 09:12 PM
Quick Reply: Revtech 88" Pandemonium engine
