Unhooking battery & Alarm effects?
I need to take the cables off the battery on my '07 Sporty to add the pigtail for the Battery Tender. Will this effect the alarm system in any way? I don't want to have to go to the dealer & get it re-programmed.
Sorry for the dumb question.....![EEK!](https://www.hdforums.com/forum/images/smilies/eek.gif)
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I was king of wondering the same thing.....
My 2003 FatBoy has the security system, FOB (or whatever it's called), but I've never used the system.
Wasn't sure what would happen if I pulled the battery.
Wonder if there is any easy way to remove the whole setup since I'm not using it. [8D]
![](http://dogsdoom.com/PI/fatboy-fav-07.jpg)
I took the cables off the battery a couple of times while in the process of swapping out my bars and everything was just fine after re-connecting them.
CN
CN
Disconnected battery to change starter. I have no power when i hooked battery back up. It shows charged. I get no lights also. 2000 FXDWG with HD alarm. Alarm is not set of either.
Any suggestions?
Any suggestions?
ORIGINAL: Hidalgo
I got a batter tender jr. for Christmas. I want to mount the "battery end" permanently. Do I need to put "lugs" on the end of the cables, or just squeeze 'em in with the other stuff on the battery?
If I'm not mistaken, the only time you would experience a problem with the alarm system is if you attempted to disconnect the battery cables WHILE THE ALARM WAS ENGAGED. Doing this would facilitate having to have the alarm reset/recoded and also result in difficulties getting the bike started up again. But if the alarm is not engaged, disconnecting the cables should pose no problem whatsoever.
