Zumo Security Screw Driver
I had the screw driver on a key ring on the bike. I guess I didn't get the top screwed on tight enough. The top came off somewhere on the road. I tried to find a replacement screw driver on the Garmin site and found none. I called them and didn't want to wait 35 minutes for a rep. I asked about a replacement on the Zumo forum and received no reply. Has anyone lost their screw driver and ordered a replacement? If so, do you have a part number? Thanks.
[IMG]local://upfiles/1638/29FB6759CE0A49BBAC4B826495D7D5CE.jpg[/IMG]
RE: Zumo Security Screw Driver
if you don't get anywhere...just get a small regular screwdriver........like one from a "jeweler's kit" and grind the necessary notch in the middle of the blade........that's what I did and it works great.
My top fell off just walking around the house. I use the blue locktite now. You still have the screwdriver just not the top, right? You could try a plastic pen top that would thread itself on there, or a small piece of hose. Or just forget about a top all together.
I have to ask about this. Unless I'm not thinking about something correctly, I've always wondered how useful that security screw really is. While it might prevent someone from pulling the GPS out of the cradle while one is parked, it would be a simple matter to just pull the entire cradle off the motorcycle and walk away with that.
It's just one of those things I've always wondered about when I think about using that security screw.
ORIGINAL: Tralfaz
Dump that stupid little screw and get the replacement thumbscrew that Clammy pointed you to. You're going to take the unit off the bike anyway when not attended (unless you're a total idiot) and the thumbscrew allows you to do this quickly without tools.
