Trouble Code - Cant Clear it !!!
My 2005 Road King is showing an historical code - engine light comes on again for about 5 secs after start. I have gone into DIAG MODE on the speedometer but when I enter the code areas with the PSSPT displayed Flashing first P for ECM I get NORSP displayed.All others show NONE other than the Tach area which as I dont have a Tach also shows NORSP. I have checked all fuse for the ECM and checked the connectionsand everything is good. Have any of you any idea what is causing the NORSP display for the ECM?????
RE: Trouble Code - Cant Clear it !!!
JB - BIG thank you for that!!!! You were quite right I was trying to clear the code without turning on the run switch. Everything is OK now.
Thanks a lot !!!!
Thanks a lot !!!!
