Tires & Tire Changer - My Decision
#111
The filler neck on my truck is cap-less.
There are 2 hinged flaps inside the neck. I suspected the short spout on the No-Spill can wouldn't be long enough to open the 2nd flap. My suspicion was confirmed when I got the can home.
Cosmic Razorback (09-04-2024)
#112
#113
Thanks, I picked one up today (2-1/2 gallon). I'll be using it for filling the tank on my riding lawnmower. I also picked up the flexible spout extension in the event I need to add gas to my truck.
#114
Unfortunately, when it is fully inserted to open the 2nd flap, the funnel end doesn't stick out far enough to be used effectively with the short No-Spill spout.
If the can was completely full, I might be able to dispense 1/2 gallon. In order to dispense the entire 2-1/2 gallons, the spout needs to be vertical.
#115
Received 49,835 Likes
Goose_NC (09-07-2024)
#116
Uncle Larry (09-07-2024)
#117
That's the filler neck on my truck with the supplied funnel fully inserted. I was holding the phone parallel to the floor with the camera lens directly above the funnel.
Here's a different angle. I placed a 1-1/2 inch O.D. washer inside the funnel to illustrate the small opening. The washer is sitting about 1/8 inch below the funnel lip.
#118
#119
Mission Accomplished
Today was the day. Ginger, our 22 Road Glide has new shoes front and rear.
I wish I could say it was super easy but I struggled a little on both the front and the rear.
These tires are just so stiff! I place the new Commandar III's in the sun for a couple of hours which helped. The Dunlops were cool.
I really didn't know how little thread was on the rear tire until I removed it. I'm due for inspection and it would not have passed.
Balancing these was therapeutic. I played with them a while until they were perfect.
This was my first time ever removing a rear wheel and setting the belt tension. All went smooth and doing it myself allowed me to throughly clean the wheels and other parts of the bike.
I worked from the floor using my scissor Jack's and it went very easy.
I removed the tail pipes because we wanted to install the stock SE pipes back on the bike. I'll have a smokin deal on a pair of Supertrapps. Great pipes, just a little louder than we want.
Thanks for all the comments, help and suggestions.
I'll take her for a test ride tomorrow and report on the tires.
The following 12 users liked this post by Cosmic Razorback:
dawg (09-08-2024),
Germansheperd (09-08-2024),
Ghetto blaster (09-08-2024),
Glenn Gorman (09-14-2024),
gonemad (09-08-2024),
and 7 others liked this post.
#120
The following 3 users liked this post by Uncle Larry:
