Notices
battery tender question
Old 08-14-2024, 09:47 PM
Jshopes's Avatar
Jshopes
Jshopes is offline
Received 1,280 Likes on 705 Posts
Default battery tender question
so, ive got an hd tender that plugs into my ultra limiteds included battery charger and it does its thing. last week i unplugged it and plugged in my goldwing that has an added charger. the charger didnt acknowledge that it had been plugged into the bike. is this normal and i need to buy a new charger for the wing? or is the charger taking a crap? i feel like the charger shouldnt care which bike its plugged into.
thanks!
Old 08-14-2024, 09:56 PM
cprhed's Avatar
cprhed
cprhed is offline
Received 1,089 Likes on 628 Posts
Different batteries perhaps
Old 08-14-2024, 10:00 PM
Northern Glide's Avatar
Northern Glide
Northern Glide is offline
Received 3,917 Likes on 2,815 Posts
Check the polarity of the charge wiring leads. Just a thought between brands.
The following 2 users liked this post by Northern Glide:
cprhed (08-14-2024), Jshopes (08-15-2024)
Old 08-14-2024, 10:05 PM
aharleyrider's Avatar
aharleyrider
aharleyrider is offline
Is this a question for a Honda Gold Wing forum?
The following 2 users liked this post by aharleyrider:
seniorsuperglideE8 (08-16-2024), Vec (08-15-2024)
Old 08-14-2024, 10:45 PM
Rusty Springs's Avatar
Rusty Springs
Rusty Springs is offline
As long as the charger is compatible with the type of battery it will work. I suspect the wing is wired differently, has a blown fuse or a bad connection somewhere. The battery isn't completely dead is it?
pgrchaplain (08-22-2024)
Old 08-15-2024, 05:02 AM
Jshopes's Avatar
Jshopes
Jshopes is offline
maybe if it was about the goldwing but its about the hd branded charger and if it cares what its run through.
The following 2 users liked this post by Jshopes:
jaskoller (08-22-2024), Uncle Larry (08-15-2024)
Old 08-15-2024, 05:04 AM
Jshopes's Avatar
Jshopes
Jshopes is offline
ill check when i get home, i didnt even think of that. ive had the battery unhooked in the wing but i thought i put it back together right. seems like the most plausible scenario. thanks.
Old 08-15-2024, 05:06 AM
Jshopes's Avatar
Jshopes
Jshopes is offline
its just got the standard leads that come with every tender ive seen and theyre both lead acid batteries. as was suggested i need to make sure the terminals arent reversed.
Old 08-15-2024, 05:07 AM
jake24lt's Avatar
jake24lt
jake24lt is offline
Received 1,517 Likes on 818 Posts
If the charger sees 0 voltage , for whatever reason, it wont try to charge. Also, what is "an added charger"?
Old 08-15-2024, 05:10 AM
Jshopes's Avatar
Jshopes
Jshopes is offline
the harley has the charger thats integral to the wiring harness the wing has 2 leads coming off the battery that were added after it was built. the wing really isnt relevant, just that its another lead acid battery that isnt run through hds integrated pigtail.
Quick Reply: battery tender question
