battery tender question
The following 3 users liked this post by Red:
If you have a known good tender (it works on your Ultra) and it doesn't "work" when plugged into the Goldwing then there is clearly something wrong with the Goldwing. Assuming the Goldwing starts, indicating the battery isn't stone dead, then my guess is you don't have a complete circuit on the tender lead; ie, broken wire/terminal, or blown fuse. A battery is a battery and the tender lead is an SAE connector that is standard throughout the entire industry, it's not unique to either HD or Honda.
I've used the one I got with my HD on my Corvette and travel trailer multiple times without issues.
Jshopes (08-15-2024)
True, but the pigtail will still show 12 volts if the ring terminals were inadvertently reversed on the battery posts. Most modern battery tenders won't initiate a charge if the circuitry detects reversed polarity.
Received 49,832 Likes
Received 12,267 Likes
Pulse Tech
PulseTech Products - Xtreme Charge XC400 charges and maintains ANY 12-volt lead-acid, VRLA, AGM, gel and flooded cell batteries.Recover and maintain up to four batteries at a time with our QuadLink 4-Channel Battery Charger Multiplier.
https://pulsetech.com/products/xc400...tainer-charger
Comes highly recommended by Rick Fairless.
https://www.strokersdallas.com/ `
Uncle Larry (08-15-2024)
