plug under seat
Old 08-29-2007, 10:32 PM
paparazzi's Avatar
paparazzi
paparazzi is offline
Stage III
Default plug under seat
Hello everyone. Just bought a 07 street glide from a car dealer with 124 muiles on it. i did not get a manual with the bike and had a question. There is a electrical plug with a cap on it right below the seat area. What is it for?
Old 08-29-2007, 10:36 PM
drdiesel1's Avatar
drdiesel1
drdiesel1 is offline
Default RE: plug under seat
Accessories. The switch on the dash controls it. How much $$$$ if I may ask....??????
Old 08-29-2007, 10:44 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
Get a maintenance manual
Old 08-29-2007, 10:47 PM
Matrix's Avatar
Matrix
Matrix is offline
Trace the wires, does it go to the battery only?
If it goes straight to the battery it may be a battery tender (Charger), a plug in for heated gear ora diognostics plug.
Post a picture of the plug, this might help youget a quicker and correct response.
Old 08-29-2007, 10:51 PM
Matrix's Avatar
Matrix
Matrix is offline
You may get a better response from the Touring forum also.
Old 08-29-2007, 11:34 PM
Cryptoboy's Avatar
Cryptoboy
Cryptoboy is offline
Received 3,878 Likes on 1,415 Posts
Most likely it's for the battery tender. That way you don't have to take the seat off to trickle-charge the bike.
It could be for accessories, but I think it's more likely attached to the battery.
Old 08-29-2007, 11:54 PM
scoobs's Avatar
scoobs
scoobs is online now
If it's one of those male/female combo connectors, it's most likely for the trickle charger that you can buy from the dealer. My dealer puts them on all the new bikes out the door as a convienence. Trace it back to make sure though. You can also make up a cig adapter to use for a quick charge on the cell phone etc....
Old 08-30-2007, 12:30 AM
Arizona Flash's Avatar
Arizona Flash
Arizona Flash is offline
There's an accessories connector and another connector for an optional security siren, both buried under the seat. But since it's an '07 and it sounds like you can see it pretty clearly, it sounds like the connector for the un-used exhaust actuator, also called an "Active Exhaust". This connector is also under the seat area but you can see it clearly from below. It's a 5 place "AMP" connector that only has 4 wires going to it but the connector is not connected to anything. Just uselessly hangs there with a cover on it. The rest of this funky exhaust actuator system is only on international models. It actuates a cable that controls a baffel in the exhaust pipe. An exhaust noise control system that we fortunately don't have to use here in the US.
bfon1987
General Topics/Tech Tips
03-06-2014 09:42 PM
Taranwanderer
12-25-2013 04:04 PM
TriGeezer
10-26-2013 07:49 PM
HarlyFan
10-03-2007 09:28 AM
soulfish
08-12-2007 04:04 AM
Quick Reply: plug under seat
