removing reflectors and adhesive
RE: removing reflectors and adhesive
Fishing line to remove reflectors........Goo-Gone or Goof Off to remove adhesive.
ORIGINAL: grimm
don't be shy. just get in there and pull them off. WD-40 will dissolveany remainingresidue.
dental floss and wd40 to remove the adhesive. I sprayed let it soak in then used the floss as a cheese cutter it took a few tries. kept spraying with wd40. once off use a soft cloth and wd40 to clean remaining adhesive.
some people use heat guns or blow driers to heat the glue and remove them. I did not so have no comment on it. heat and paint scared me.
ORIGINAL: whaap
I've always keep a can ofcigarette lighter fluid near my workbench. It has never failed getting the goo off of anything.
