Any Stone bruises on windshield fixes?…
The following 3 users liked this post by 702:
There's 2 types of materials commonly used to make windshields....Polycarbonate and Acrylic...and the short story of differences between them is that while PC is more resistant to shattering and/or cracking?...as a standalone material it is very susceptible to hazing and yellowing from UV rays unless?..."a coating is applied"....and such is the case with my '22 FLHCS 114 stock windshield which BTW?....I can't just order the shield itself...Harley only sells it as an assembly complete with brackets for $560 while my deductible is $500 so I'm calling it a wash but that's okay and here's why...
It's true that you may be able to both clean and remove "fine scratches" from the extremely thin UV coating that a PC windshield requires with a very non-aggressive polish however?...if that scratch is deeper than a few thousandths of an inch deep or like in my case is a road pebble ding that was like .005-.01" deep?...you better learn to live with it cause you're screwed.
And the above is why there are a good number of premium aftermarket windshield manufacturers that expound the benefits of Acrylic over PC with the reasoning that Acrylic has UV inhibitors built into the material itself and therefore requires no thin coatings which in turn means that if this pebble ding of mine...(or any scratch deeper than "fine")...was in acrylic instead of coated PC?...I wouldn't be shopping for a new windshield right now and it would've taken me maybe 30 minutes to polish that pebble ding out and this thread would've been a success story instead of what it is....a learning opportunity.
Sure did! LOL! Ya know?...it was a "That first scratch on a new car moment" for me so I immediately grabbed my fine grit scotchbrite and my polishing compound I'd had so much success with many times before polishing out things like scratches and chem attacks from DOT brake fluid on clear plastics such as gauge cluster covers (and apparently acrylic windscreens) on sportbikes but?...not this time and within my first few light passes with the scotchbrite and seeing the material change?...I got that sinking feeling knowing I just screwed up.
I'm looking at "Freedom Shields" (premium motorcycle windshields)...they are a bit pricey but have the best warranty and are a recurve type shield made of thick, optically correct acrylic and seem like the way to go as dings and scratches can be polished out of such.
M Oclaf (10-16-2022)
