Tire wear
The pressure noted in the manual and on the frame have some stipulations. Those are pressures for standard riding weight (whatever that is) and there might be a passenger PSI as well, cold (not ridden) and at 68°F air temperature. You adjust for more or less weight and + 1 PSI for every 10°F the air temperature is warmer and -1PSI for every 10°F it is colder, that's if they have the pressure right to begin with. (Firestone and Ford Explorer ring a bell?), they are trying to get a class action on Dunlop for the Harley OEM tires (mostly touring IIRC).
There are methods to get the correct pressure for your tires.
P.S. Best is to always use the same gauge when possible, after determining the proper pressure.
j/k... bustin your *****. (i think) pretty sure you meant 11,000?
I just put a new Dunlop on the rear of my heritage last fall only about 6000 miles ago. Went to check my tire pressure today and noticed it was already down to the wear bands. Anyone else have one wear that quick? I haven't, no burnouts no hard downshift very little two up. Lots of mountain backroads and interstates.
Normally get 18,000 to 19,000 out of the fronts and between 10,000 and 11,000 out of the rears.
fullautomike (06-28-2022)
