Wheel Chock for 5' X 7' Trailer
#32
It is a bit pricey however and if I recall it’s kind of a single use application in that different styles of bikes require different bars.
I don’t see however by design how it would come loose during travel if it’s installed correctly.
But it only takes one time to not be installed correctly or a catastrophic failure to make for a bad day so using it alone wouldn’t be something I’d do.
I personally would never use a single method of tie down simple due to if the single method fails the bike’s going over.
Even if I used the Biker Bar I would still install 2 straps for back-up/peace of mind.
wombat457 (06-22-2022)
#33
I am going to go with the Condor Chock. Which version is still in question for me though
Right now, I need to replace my mirrors as they are as loose as hell and flop all over the place.
#35
Wombat
You mentioned that you have never trailered a bike before. I have no recommendations for a wheel chock that hasn't been mentioned already.
As an FYI, if your bike has a security system then make sure it is in transport mode when trailering. Otherwise, the alarm will be going off constantly and you will have a weak to dead battery when you arrive at your destination. Your Owner's Manual will have the procedure to enable/disable transport mode.
#36
#37
Good information in this thread. I have a 5x8 utility trailer with a $20 wheel chock. I used it occasionally with my FXR but I had to use it with my Ultra bringing it home from FL. It worked but I plan to get something better. I really like the Wheel Dock and it supports a small business and MADE IN USA. I'll have to get one if I end up using the trailer for the bike again. I plan on riding the Ultra on most trips but you never know.
#38
I have a Trackside “roll-on” wheel chock that I picked up after towing my bike the last time without a chock and bending my jiffy stand. Little under $100, and quite solid. Can and should be bolted to a trailer or the floor. I haven’t had to haul my bike with it yet but it holds my bike up just fine in the garage.
only deal breaker may be is that a 120mm front tire is probably they largest you’ll safely get into it. I believe the condor may work better for 130mm+ front tires.
#39
BigMike (10-05-2022)
#40
