Tire Pressure vs Contact Patch
Old 06-18-2022 | 10:00 PM
perki48's Avatar
perki48
Originally Posted by FatBob2018
People do lots of stupid-*** things to try to squeeze more mileage out of a tire, like overinflating them, or even using car tires that don't have the proper safety bead for a motorcycle rim.
Inflate it to the proper pressure.​​​​
So my car rim laced to my motorcycle hub is OK with a car tire?.............Ran it for many years.
Old 06-19-2022 | 07:14 AM
GOV5's Avatar
GOV5
I never have seen that anywhere. Thanks for posting that info. Put's a different perspective on going "DARKSIDE", doesn't it?
Old 06-19-2022 | 01:54 PM
FatBob2018's Avatar
FatBob2018
Fortnite dug into the whole "darkside" thing, and pointed out the issues. It can work, people have done it successfully, but there are definite issues, which raise the question of whether it's a good idea overall. The rim stuff is about 4 minutes in, but the whole thing is worth watching.
eighteight (06-21-2022)
Old 06-19-2022 | 02:23 PM
glasspilot's Avatar
glasspilot
Originally Posted by perki48
..The riders manual for the 1948 Panhead shows the tire pressure for a solo rider and one passenger at 12lbs front and 16lbs rear for the 5.00 x 16 tire
Of course those are tube tires. For what it's worth.
Old 06-19-2022 | 05:18 PM
perki48's Avatar
perki48
As are many NEW Harleys.
Old 06-19-2022 | 08:24 PM
Tjroadie's Avatar
Tjroadie
Bike tires are more complex to read wear than a 4 tire vehicle but it's still there. Too much air wears the center out, too low tends to cup the outsides. Since I now have a tpms system I'm more intrigued by pressure build up as the front on my flhtk builds normally 4 psi hot and air temp runs true to ambient temp. The rear builds 10 psi and air temp runs 20° more than ambient. So I'm dropping the rear a few lbs from recommended as I run 2 up and packed 90% of the time and I tend to wear out center tread early. So this set of Dunlop AE's are about toast. I'm eager to see what happens for the next set.
18Slim
2018+ Softail Models
07-27-2019 11:31 AM
nevera7
2014-2023 Touring Models
38
04-26-2017 10:26 AM
WVDevil
Wheels/Tires
05-19-2015 09:59 AM
S.D.M.F
10-14-2012 04:07 PM
John TN
05-03-2005 01:47 AM
Quick Reply: Tire Pressure vs Contact Patch
