Handlebar Advice (tank lift)
I posted this in the Dyna section but didn't get a response so I will try here. The drag bars (TT Style) I have now are 30 1/2 inches wide and 8" risefrom the triple tree to the top of the bars and 6 3/4 to the bottom of the bars. I want to install my 2" tank lift and was wondering if a 10" rise bar would do the trick or if it would be too much or too little. Want to get it right the first time since I will be running the wires through the bars when I replace them. Any advice would be apreciated. I own a 04 WG. Thanks.
RE: Handlebar Advice (tank lift)
I have Wild Ones drag bars on my '05 WG, and I think the rise is only 8", and they fit ok. All you need to do is go out to the bike, take the front mounting bolt out, loosen the rear bolt, and lift the tank 2" and see if everything clears ok.
rdown1976
01-13-2010 10:38 PM
