End the humiliating horn sound advice needed.
Old 05-30-2022, 03:07 PM
BareKnuckle's Avatar
BareKnuckle
BareKnuckle is offline
Originally Posted by Stiggy
Another vote for the Denali Mini.
I had to do something with my Kaw's 'pancake' horn! I tried the Denali and was sold. I found a spot on the lower right front of the engine to install it as that bike has no frame under the motor.
I got another for the Dyna, and with small modification I fit one under my stock cover as well.
Great sound for not a lot of money.
$35 well spent & worth every penny!
  #32
Old 05-30-2022, 05:12 PM
Spartanden's Avatar
Spartanden
Spartanden is offline
Received 8,297 Likes on 6,040 Posts
Like SoldierBot, I have the Custom Dynamics Mini-Beast. Replaces the stock horn just fine. And to me, it sounds like the old Army Duece-and -a-half!!
soldierbot (05-31-2022)
  #33
Old 05-30-2022, 06:58 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 14,350 Likes on 6,143 Posts
Originally Posted by Frostbite
Last time I needed my horn I left blinkered the hell out of them.
Yup. I needed my horn today when a guy in a Ford Explorer wanted to share lanes at 80 mph.
I went for the horn but gave him my high beam instead. POS design on the 95 and earlier hand controls.
  #34
Old 05-30-2022, 07:30 PM
rjg883c's Avatar
rjg883c
rjg883c is offline
I don't know about the 95 and earlier hand controls. But when I tried to use the horn on my '07 it was much more difficult then the little
button on my metrics had been. After a few years, and a little practice, using the Harley button was a little easier. But is was still more difficult then it should have been.
Especially in an emergency situation. That means alerting a cage driver of my presence before he does something stupid.
Then I got a "LifeSaverHorn", I think it is called a Horn Trigger now, and made the process much easier.
  #35
Old 05-30-2022, 09:18 PM
hellonewman's Avatar
hellonewman
hellonewman is offline
Received 6,511 Likes on 2,710 Posts
Whats this? Your martini shaker?
  #36
Old 05-31-2022, 01:01 PM
soldierbot's Avatar
soldierbot
soldierbot is offline
Received 104,020 Likes on 26,136 Posts
Harley Brand storage tube. Used to use it quite a bit before just going with a swingarm bag.
Martini shaker? now you've got me thinking.
  #37
Old 05-31-2022, 04:02 PM
Redbeard's Avatar
Redbeard
Redbeard is offline
What did you have to do? Did you modify the horn or the cover itself?
  #38
Old 05-31-2022, 05:23 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,818 Likes on 3,172 Posts
The cover. I removed the tab that normally would bolt to the motorcycle and added my extended tab to the motorcycle and bolted the horn and cover together on the low side. I used the bracket that I think (?) came with the horn. Hope that helps!
Redbeard (06-09-2022)
  #39
Old 05-31-2022, 08:50 PM
Ingramite's Avatar
Ingramite
Ingramite is offline
Received 1,280 Likes on 549 Posts
Get a bicycle jingle bell on your handlebars.
That way all the kids will think the ice cream man is coming .
  #40
Old 06-01-2022, 05:05 AM
galtjunk's Avatar
galtjunk
galtjunk is offline
I use the chrome Wolo Bad Boy mounted in place of the cow bell.
I use a circuit breaker instead of a fuse because when I use it I tend to run it until the fuse would blow.
The horn will come loose from the compressor after a few years.
A zip tie will hold it in place for a few more years.
It would last longer if I split the horn from the compressor and mounted them separately.
Quick Reply: End the humiliating horn sound advice needed.
