final breather question.
I've been having a bit of oil leaking from the breather system so I'm going to an external breather. I'm replacing the backing plate bolt type on the left with the bolt type on the right. Would I be right in thinking a bit of thread sealer on the end of the new bolts where they screw into the heads would be appropriate?
Hylomar Blue, won’t eat orings. I wouldn’t do the threads with anything they don’t back out. Seal the air cleaner boss to head, and the bolt shoulder to air cleaner. This fix worked on mine to eliminate oil creep in these areas.
https://hylomar.com/en/universal-blue/
Get the original - not the US Permatex knockoff which is a runny mess. I got mine thru Amazon.
HD says to use the blue loctite on those in their Screamin Eagle air cleaner kit. https://serviceinfo.harley-davidson....0?locale=en_US
