Tires ?
The following 3 users liked this post by QC:
Some light reading for you.
https://www.hdforums.com/forum/touri...re-brands.html
https://twistedthrottle.com/blog/do-...need-to-match/
the biggest reason is that they are not designed to work with each other. does that mean they won't? not at all. but, no company is going to tell you that their tire will work with x company's tire, so it's going to be pretty much up to you to experiment with it yourself. the biggest thing is if you are going to mix radial/bias, the radial goes on the rear. and make sure that the tire that you select has a sufficient load rating for the bike you're putting them on.
The following 3 users liked this post by skratch:
A few years ago I had Metzeler 880's, front and rear. Was changing the front wheel to different rim size and went in wanting an Avon Chrome tire on the front. I let the local powersports place talk me into Dunlop American elite for the front, said all the Harley guys love them, so I said OK. Kept the Metz on the rear and I was happy with the Dunlop. A few months later the rear Metz was worn and I went with Avon Chrome on the rear. quickly found anytime over 55MPH I had a weird shimmy/wobble that only go worse with more speed, or a crosswind over 20mph. Went over the whole bike, tire pressures, shock adjustments, axle nut torque, rear axle alignment, motor mounts, etc. Finally replaced the Dunlop with Avon Chrome and the bike was back to solid.
So...
1 don't let pushy sales people talk you into something you don't really want
2 Keep the front and rear tires same brand
True story.
So...
True story.
OP What this fella said is my thinking as well
WP
MarlinSpike (03-03-2022)
IMHO..I’d think a sticky front tire, and not so sticky rear tire wouldn’t behave well pushing it in the twisties. I was an Engineer, but not a tire or vehicle Engineer…so this is my opinion. Not to be confused with technical analysis, finite element modeling, imperial data, or anything else that would validate my hypothesis.
