Crate motor vs building a motor from scratch
I would say, if you are a builder/machinist and knw what and how to do it ,then it would make sense to build it. If not and doing a swap is within your capabilities, then do a rate swap. Its more cost effective.
With any engine build you need to take measurements and determine what needs to be machined, what parts to order etc. that is time and money in the end it may be cot effective with a crate engine with a warranty.
OFA (02-15-2022)
gregintenn (08-10-2022)
If I were to do a build, I'd be paying a lot of labor for a skillset I don't have. I can and have swapped engines on numerous vehicles. I priced it out and dropping in a 131 crate still ends up costing about $9k by the time it's done. A stage IV on my current engine would cost considerably less.
That being said. the MOCO has several Stage III and Stage IV performance kits for Twin Cams and M8's in the $1,800 to $3,500 range.
S&S, Dark Horse, and several other fantastic companies sell performance parts. Lots to choose from and that's good.
IF I read the OP correctly he does NOT have an existing engine to modify ( "not building a current motor" )
Obtaining individual "speed parts" might be further complicated by location , I assume Bombay means Mumbai India
There is however a dealer there , and 28 others throughout the country
If identical motors (same parts/specs). I'd say crate motor hands down (cost, labor and quite likely better quality). If you want something special and have the time and ability to build then go that route. Cost may be about the same as buying a crate engine and making small mods. With major modifications it will probably cost less.
All depends on if your capable/comfortable doing the work yourself vs. paying someone else to build it. If your not, then a get a few quotes on the work you want done and compare that with buying a crate engine. Remember if you did go crate you would have less downtime and could recoup some cash selling your old model. Just my 2 cents. Tough call
Jim
Jim
Unless you or someone you know well and trust with your open wallet has lots of HD build experience, crate for sure. Are you going to have registration issues after? Do you care about resale value at all? What kind of performance are you after? What’s the fuel like where you live? Lotsa details you should sort out before the first dime is spent…
