HD Lithium Battery (new/updated version)
Old 05-10-2022 | 11:10 PM
RET_SCPO's Avatar
RET_SCPO
I was looking at one of these new Lithium batteries but will stick with the OEM battery. For the price they're pretty good. I'm on my third riding season with my original battery and it's still going strong. I didn't even bother putting it on the tender over the winter this year.
Old 05-11-2022 | 06:32 AM
603Hog's Avatar
603Hog
Did you disconnect the negative battery cable for the winter? If you didn't, I would be shocked (no pun intended) that the parasitic draw of the bike's security system didn't kill the battery. Mine sat on the tender all winter, no disconnecting the battery cables. Fired right up when I started it for the first time this year.
Old 05-11-2022 | 06:37 AM
ajtwin's Avatar
ajtwin
This bike is awesome!
Amazing work 💪
Originally Posted by sharkey
Had a Shorai in my FXDXT, was part of a weight lo$$ program that included aluminum swingarm and Lyndall carbon rotors as well as aluminum excel rims…lotsa money expended for excellent TOTAL results. To just get a Li battery? Wouldn’t bother
Old 05-25-2022 | 09:43 AM
adam072987's Avatar
adam072987
Not sure how the HD batteries stack up by I added a Anti Gravity to my Slim S which really struggled to start in the cold with a OEM battery and it worked great. When it comes time to get a new battery I will prob go with the Antigravity ATX30-HD Lithium Battery . Seemed to work very well when my bike was close to freezing. .
Old 05-25-2022 | 10:14 AM
ahhlou's Avatar
ahhlou
Most AGM batteries for HD are about 30 AH of capacity (or higher). Until HD offers a 30 AH Lithium battery at a reasonable price, I'll pass...
Old 05-25-2022 | 10:18 AM
willcasp's Avatar
willcasp
I use LiION (Shorai's) on several of my other motorcycles. The technology is a mixed bag. I like it, but there are a lot of caveats. It is not a simple 1 for 1 swap.
- they are lighter. For dirt bikes, this is a benefit
- you can fit more CCA and energy storage in the same size package as a "regular" battery, so they do tend to work better PROVIDED that you get a larger capacity than you have in your ACM or LA battery
- cold weather affects them. If you live in cold climates, this might not be a good option!
- if you don't have a parasitic charge, they do tend to retain charge longer than a standard battery
- you do need a different type of tender to properly charge them
- they take longer to recover from a start than a more standard battery.
- the discharge pattern is different than it is with a standard battery.
toku58
05-16-2016 10:48 PM
ThinkWired
10-26-2013 08:54 PM
MixedNuts
09-10-2011 03:05 PM
tx-skydiver
05-27-2010 11:48 PM
Jameson
05-15-2007 11:06 AM
Quick Reply: HD Lithium Battery (new/updated version)
