Help identify this Shovelhead frame please!
The following 2 users liked this post by Uncle G.:
Dseago1969 (01-25-2022),
hdrebuild63 (05-15-2024)
The following 2 users liked this post by OLD 96:
TwiZted Biker (01-25-2022),
Uncle G. (01-26-2022)
Looks like a stock frame somebody did an add on hardtail section and did some other mods too, tank & dash mount is buggered up with a few other additions. Factory frames of that design had casting for the axle plates and you can see the weld joint on the lower rear section by the trans cross tube mount. Did a number of those back in the 70's.
The following 4 users liked this post by TwiZted Biker:
Mike, welcome to the forum. Re the forging number on the front mount, I do not know what the letter Y represented but apparently it was added around 1973 and therefore it helps indicate Shovelhead. To the right it looks like there is a forging hallmark and a forging die number?
Rear mount forging number is 47671-58-Y. Apparently this Y was also added around 1973 so it too helps indicate Shovelhead.
Notice on the top mount the date code is on the left side as opposed to the R-H side. Therefore in this instance date code I 9 indicates the frame was made in September 1979 and it was probably used as a 1980 model.
Looks like the VIN boss has been removed?
As mentioned above the frame has been hardtailed but I don’t know if the hardtail is aftermarket or homemade.
Eric
Eric
The following 2 users liked this post by Speeding Big Twin:
Architect (01-26-2022),
LetEmWaltz (01-26-2022)
Thank you guys so much. Yes the hard tail was added at some point. The trans mount reads 47671-58-Y. I was thinking 79 as well. Again thank you guys.
top motor mount- I 9
front motor mount- 47664 48 Y
trans mount- 47671-58-Y
no vin.
Building my first chopper.
no vin.
