96 vs. 96B ?
08-08-2007, 09:37 PM
96 vs. 96B ?
with the counter-balancer on the "B", how much horsepower/torque is robbed vs the 96 ?
08-08-2007, 10:08 PM
RE: 96 vs. 96B ?
Don't know on the 96, but read quit a while backthat the 88b was around 7hp less than thenon-balanced.
08-09-2007, 07:29 AM
RE: 96 vs. 96B ?
Not enough to worry about it!!!
08-09-2007, 08:35 AM
RE: 96 vs. 96B ?
RPM=HP, SINCE THE REV LIMITER IS SET LOWER ON THE"B: MOTOR = LESS HP. SPIN THEM BOTH @6200= SAME HP
08-09-2007, 08:40 AM
RE: 96 vs. 96B ?
Also noticed that the torque peak is different. The 07 96b is around 2700 and the 0796 is around 3300
08-09-2007, 08:45 AM
RE: 96 vs. 96B ?
Two simple rules:
If you plan on doing heavy mods for performance the "B" isn't for you.
If you don't plan on going for performance the "B" is for you.
08-09-2007, 09:19 AM
RE: 96 vs. 96B ?
what were the peak torque #'s ?
08-09-2007, 09:28 AM
RE: 96 vs. 96B ?
07 96b = 89.7@2750 08 96b = 89@3300 07&08 96 = 92.6@3500
08-09-2007, 11:50 AM
RE: 96 vs. 96B ?
Quote:
ORIGINAL: deluxxxe
Just to clarify, these numbers are at the crank not rear wheel.
08-09-2007, 12:32 PM
RE: 96 vs. 96B ?
Don't forget to include the 100+lbs difference between 96 & 96B powered bikes.
