Shifting without the clutch
Take a look at some blow-up charts of Harley gears/shafts and then those on cars/trucks,and even MotoX bikes.
The largest factor is what speeds up the gear so it will mesh.
On MotoX bikes you have thrust washers, obviously they do a great job in speeding the gear/shaft up.
On cars/trucks some gearsmesh at speed without the clutch, but not all.
If you look at the splines on those shafts you'll find idlers that help mesh the landing gears.
ORIGINAL: TXSwede
I usta do it alla time with my old ironhead Sporty, and I mean ALLA time. Mostly upshifting, I just thought it sounded cooler without that annoying fraction of a second lapse it took to squeeze the clutch lever.....let it back out.........then throttle back. All you had to to was let off the throttle for a nano second kick her up and rev on! This was 20 years ago, though. The only time I have done it on my Dyna was by mistake! Brought back memories tho!
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
street racer 1960s style
...Hey Bear, I raced a 1970 XLCH, bracket class NHRA, during the 70's, man...those days were fun. ![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
(Remember those oil catches NHRA made us put on the front of the engines? HeHe, 2 funny now...)
I usually just give the clutch a little bit of pull to release pressure on the gear teeth so they will slide. I don't hear or sense anything getting chipped in the process.
ORIGINAL: MOSTWANTED
actually in a truck transmision it cuts down on wear and tear on the clutch. Just got to do it without grinding the gears.
edit: Bear64 beat me to the idea.
Personally, and im no rocket scientist but im sure a few of them have had some input on this over the years. Theres probably a reason that all these vehicles have clutches on them.....Dontchatink?
I have with most of my vehicles. With my dirt bikes, I don't think I ever used it except to start and stop. And when I was driving Semi's same thing. It's just a matter of shifting when there is no load on the drivetrain.
ORIGINAL: Unamed
Of course it cuts down wear on the clutch! your not useing it!!!! Sheesh!![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
ORIGINAL: Unamed
![EEK!](https://www.hdforums.com/forum/images/smilies/eek.gif)
[IMG]local://upfiles/3092/CFDFE4D800AF4670BDA5BF595B28D6C6.jpg[/IMG]
ORIGINAL: Bear64
your so right, but then its like living in the fast lane, or riding 20,000 miles a year?? Can I really do that? but then there are those that do neither--Dontchathink??![EEK!](https://www.hdforums.com/forum/images/smilies/eek.gif)
ORIGINAL: Unamed
And you spelled dontchatink wrong, theres no H its "tink" comon man where have you been???
