Lithium melt down
Old 03-23-2021, 05:47 AM
Germansheperd's Avatar
Germansheperd
Germansheperd is offline
Batteries for Harley’s at Rural King made by Exide are still $92. Why on Earth anyone would go a different route is still beyond me. Plus you can use your tender/charger without adverse effects!
  #42
Old 03-23-2021, 09:00 AM
Ridewva's Avatar
Ridewva
Ridewva is offline
Before driving there I just checked RK's website and the one (Part Number: SC30LFA) they list for my Road King 1690 is "discontinued no longer available".
  #43
Old 03-23-2021, 11:47 AM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,209 Likes on 2,886 Posts
How is it that the motorcycle charging system is ok for all types of batteries, but you need a special charger for AGM, and a special charger for Lithium?
Hmmm, this slipped through unnoticed so far. Maybe this "bump" will help get an answer.
Dan89FLSTC (03-23-2021)
  #44
Old 03-23-2021, 11:57 AM
Piloto's Avatar
Piloto
Piloto is offline
Received 18,478 Likes on 5,666 Posts
Well, I live in a hot climate and am tired of changing out 1920s technology lead batteries out every two years. I really looked into getting a LI battery this time. I did NOT get one. For the price point, the benefit is not there yet. Maybe in a couple more years.
Falco144 (03-23-2021)
  #45
Old 03-23-2021, 01:22 PM
Shane T's Avatar
Shane T
Shane T is offline
Our motorcycle only charge while the engine is running and there is a draw on the system. Even then the regulator controls the charging system to keep from over charging.
  #46
Old 03-23-2021, 02:44 PM
roussfam's Avatar
roussfam
roussfam is online now
Received 7,214 Likes on 3,749 Posts
AGM only for my bikes
JustDave13 (03-23-2021)
  #47
Old 03-23-2021, 04:24 PM
Falco144's Avatar
Falco144
Falco144 is offline
The only time I use the Shorai charger is when the battery was seating "idle" for a long time. Normally the bike charging system is enough to charge the battery.
The problem with trickle chargers is that they never stop, their current level is unstable, in particular the cheaper ones.
  #48
Old 03-23-2021, 05:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,411 Likes on 5,011 Posts
I don`t think anyone here has seen a trickle charger in a decade...
  #49
Old 03-23-2021, 06:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
That`s not the answer to my question...
I know how the motorcycle charging system works.
The charging system output is relative to the resistance in the battery. It doesn`t know if the engine is running or not.
The charging system puts out 13.5-14.5 volts, the amperage will vary depending on the resistance of the battery. It doesn`t know if the battery is an AGM, a Lithium, or a lead acid.
  #50
Old 03-23-2021, 08:13 PM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
Originally Posted by RHPAW
Shoulda left it on for 5 more minutes. It would be fine.
Originally Posted by Falco144
There is a huge difference in chemistry between power tools batteries (Lithium-Ion) and motorcycle batteries (Lithium Iron Phosphate (LiFePO))....
Yes.
Ok then, you seem like the one to ask...Assuming they aren't being charged improperly, what causes those vape pens to explode in someone's pocket, or those hoverboards to ignite like we've seen?
Karma, kismet, fate, luck of the draw, whatever, good reason to give up vaping.
That!
Quick Reply: Lithium melt down
