HELP!! My 1994 Sportster 1200 XLH is blurring out between 4500 and 5000 RPM
11-26-2020 | 12:39 PM
That thing doesn't have a rev limiter, does it?
carl
11-26-2020 | 12:40 PM
Quote:
Originally Posted by
Jamesey
It splutters and feels like it wants to go but feels starved of something from 4700RPM up
Sounds like what's coming up short is your engine is starved of fuel.
11-26-2020 | 01:01 PM
blurring out ". That's a new one on me and I am not exactly young anymore.
I'd say tighten your mirrors, get more sleep and hold your head up straighter if everything is blurry.
That, or maybe you're just on the cusp of entering another dimension as you reach terminal velocity.
Sorry - no help (except possibly comic relief)
11-26-2020 | 05:48 PM
Imho, 90 mph on a rigid mounted Sportster is plenty fast enough !!
11-26-2020 | 07:54 PM
It looks like those are straight pipes. If they do not have baffles in them, you are losing a lot of torque. If the carburetor has not been rejected to compensate for the exhaust, that’s a big problem.
I forgot what the stock rev limiter is.
The following 2 users liked this post by Prot:
11-26-2020 | 09:42 PM
They used shitty advance curves in the ignition modules right around then , a lazy advance curve and a rev limiter that doesn't allow the engine to rev very high
11-27-2020 | 09:31 AM
are those drag pipes? when they were put on, was the bike adjusted or tuned?
11-27-2020 | 01:36 PM
CaffeineBuzz
It's a stock Harley head pipe with crossover and the mufflers are Harley but probably not stock.
It's not drag pipes.
11-28-2020 | 10:32 AM
6th Gear
Yes, its not for the feint hearted!!
11-28-2020 | 10:53 AM
I see this when I ride:
Am I blurred or spluttering?
OP, you might be hitting the rev limiter....
