Anyone try those "amazing gas drops" by forum sponsor?
RE: Anyone try those "amazing gas drops" by forum sponsor?
If it sounds too good to be true................................
Guys, thanks for the replies. Forgot about that one small important item...that being the turbo boost. Certainly does make sense.
Lost1: don't know what the compression ratio is at max PSI. I do know max boost on the car is about 12 psi, which was set up from callaway engineering.
ORIGINAL: sonar_chris
Just so you know, high octane gas is harder to burn than low octane gas, so unless you have really high compression or you are running alot of totaltiming on your ride, you are actually getting less performance and gas milage out of high octane gas...
Chris
ORIGINAL: tank69
Never tried those personally, but every "amazing", "super", "mega" gas additive I have ever tried in my car, HD, sportbike, dirtbike and quad did NOTHING. There is no substitute for the highest octane and cleanest gas you can buy from a station IMHO.
Chris
Anyone know the compression ratio on an 88B bored to 95" with the SE flat top pistons, SE203 cams and stock heads? I've looked all over and can't find it online.
ORIGINAL: tlb
rant is over now, sorry. i just had this conversation the other day in person. you could tell he based his decision off it cost more must be better.
ORIGINAL: electaRICK
YEA I TRIED THE GAS DROPS,,,,, MY EYES ARE STILL BURNIN!!!
ORIGINAL: spike95
