Another Trouble codes question?
Need help with 2 Trouble codes. I believe they are for a a failed TPMS sensor? 2016 CVO Limited. The codes are C0083 and C2001 attached aren’t the codes and what I am seeing on the dash. I don’t really care if the sensor is bad or even if the display shows the “RR- -“ but the red dash light is my big issue, leaving on a 1,100 - 1,200 mile ride and if anything else fails or sends a new code I won’t know since the red light is already triggered. Dealer says the TPMS is covered in my warranty BUT 10days for part delivery. Just want to confirm the codes for now.
Thanks in advance,
Matt
Thanks in advance,
Matt
Good luck and I hope someone can offer some assistance with your problem.
I was in a similar situation with my Silverado Dura-Max diesel with the "check engine" light coming on and going off whenever it chose.
The code came up as a "Fuel Temperature Sensor" but when the tech did the troubleshooting, he deermined that it was in fact the ECM!
NOT a cheap part but I didn't want to risk ruining an engine because I was too cheap to fix the real issue.
fordmano (09-18-2020)
