Klever Lever Junk
Klever Lever Junk
I read some good things about the Klever Lever on this forum so I thought I'd give it a try. For $9.99 + $1.50 handling + 6.99 Shipping I got a plastic piece of fake chrome. OK, I could live with that, it's small and unobtrusive but here's the rub. It came without instructions but the slots are tapered from bottom to top so the only logical way to install it, so it doesn'tfall off, is on the TOP of the stock star screw. To do that I'd need to remove the throttle cables. Guess I could superglue it from the bottom up, but not worth the effort and I'd never be able to adjust it.
RE: Klever Lever Junk
My Klever lever has been in place for almost 4 years now. Use it regularly. No problems. Installed it from the bottom. Want piece of mind? Put a few drops of crazy glue in the slots and then press it on, align it and let it dry before using.
ORIGINAL: desertbagger
I've been useing the same Klever Lever for 2 years. You push it on from the bottom,it will not fall off.
ORIGINAL: Navychief
What is it?
What is it?
OK, now in the know. Looked at one before a long ride but didn't know if it would be wirth the trouble. From the posts it seems like a good add on.
ORIGINAL: Navychief
