led lighting
led lighting
Looking at saddle bag Ciro lighting & was wondering if anyone has used these or have opinions on these lights? Just looking for saddlebag lights, already have turn signals & bar light on my 2017 FLXS. I would like to do the saddlebag extension lights but pretty hefty price tag.
I have the Ciro3d bag blade lights on 2019 RG, worked fine with 1157 bulbs in bullet tail lights, sequenced, changed colors fine, then, I replaced 1157 bulbs, with custom dynamics 48-led units, now the Ciro3d bag lamps, will not work correctly, fast-flash on selected-left/right, won't turn off. Put 1157 bulbs back-in Ciro bag blade lamps, works fine. Apparently the Ciro-Controller is expecting the 2 amps of sense-current. I have no room in bullet housing's for a 6-ohm / 20 watt resistors. Some say run the emergency flashers for a bit and the cambus will adjust. so far, no-luck. Anybody been down this rabbit-hole?
