Tubeless Spoke Wheel Repair
As this is your first post to the forum, welcome.
Go to your local Home Depot or Automotive Parts store and get you some good black RTV in a tube, put a smear of it over the torn area, let it cure for 24 hours. Put it back together and all should be well.
https://www.permatex.com/products/ad...esive-sealant/
On a tubelesss spoked wheel like the OP has there is a vulcanized rubber strip that is sealed onto the inside of the rim. This is completely different than a rubber rim strip which is used when replacing the tube in a tubed tire. Also the pressure involved inside of a tire makes RTV silicone a poor choice for a cure. A rubber inner tube patch "may" work, providing you clean, prep the area properly, and the adhesive seals completely around that patch, adhering to the vulcanized strip. If I were the OP I would give a rubber patch a try. I don't think that you would have a catastrophic failure if it were to not hold. You might get stranded on the side of the road. Then the fix would be to add a tube to it.
I used to replace the "rubberband" on a spoked rim whenever I put on a new tire.
The original intent was to keep the spoke caps from wearing directly against the tube.
Regardless of tube or not, a new band won't hurt.
Dealer has them. Get the right size. Don't try to repair it. It's your life.
