Half helmet vs 3/4helmet?
RE: Half helmet vs 3/4helmet?
ORIGINAL: whaap
Yeah, especially if it has a visor on it or if it is loose fitting. The wind is coming up from under the windshield causing the buffeting. If your helmet is a tad too big, go to a bicycle shop and see if you can buy some of the small foam pads they use inside bicycle helmets to adjust the size. That's what I did with my 1/2 and it helped snug it up.
I started out with a shoei RF-1000 full face,the buffeting was so bad it shook my head so i saw double vision,and my riding glasses would walk down my nose from my head shaking,after adding the fork deflector,fairing deflectors and the delflector that mounts between the forks, i realized the buffeting wasnt going away,switched over to a harley D.O.T. half helmet,no visor,and the buffeting was cut down by about 90 %. I still have some buffeting ,but not nearly as bad and i'm alot more comforable. dont ride much interstate highway so i cant comment about higher speeds with the half helmet. The shoei has sat on a shelf in the closet since it was a couple weeks old,wear just the half helmet. My electra glide has the 9 1/2" HD windsheild on it. Never tried a 3/4 helmet,maybe i will sometime.
ORIGINAL: oldgeezer
I'm the same as the other guys. I only use my half helmet for around town. When we travel, I wear the 3/4 that has a face shield.
