Bike Shakes
Bike Shakes
I just installed a HD windshield on my 05 Wide Glide. At about sixty mph the front wheel goes quickly left-right, left-right. It wobbles so badI think I'm going to loose it. What's going on???
RE: Bike Shakes
ORIGINAL: rainman1977
Just a note: The HD shop said check the front tire pressure. I did, it was a bit low, I got the PSI right and the bike still shakes.
RM
RM
Welcome to the WideGlide wobble club. Had the same thing on mine.....put a fork brace on. Problem gone.
RE: Bike Shakes
ORIGINAL: John TN
or you installed a left right turbulence windsheild.
RE: Bike Shakes
RM
RM
Did you check the steering head bearings yet? The fork brace won't hurt a thing.Other possibles, bad wheel bearings, loose axle nut oraxle pinch bolts,loose spokes, loose triple tree /fork tubepinch bolts, bad tire bead or cupped front tire (dished out areas on side thread) bad/loose handlebar riserbushings, out of true tire rim or out of balance tire.
RE: Bike Shakes
Hello rainman1977;
Check every thing that John TN suggested, any one of the items or combination of items that he listed can cause problems. Also watch following or passing semi trucks, when useing a winshield, the draft on the big trucks will cause a left, right or right, left wind blast that will whip the steering around.
Good luck with it.
Arcane
Good luck with it.
Arcane
