Grrr, primary derby cover bolts
Old 07-24-2019, 06:53 AM
Greezey Rider's Avatar
Greezey Rider
Greezey Rider is offline
Received 2,498 Likes on 1,076 Posts
Originally Posted by Stiggy
They went to torx because it reduces assembly time at the factory.
How?
I have never had one strip...Ever! If they are torqued properly and you are using the right size bit they come right out.
The following 5 users liked this post by Greezey Rider:
AJSHOVEL (07-26-2019), Crazy (07-25-2019), OldMike (07-24-2019), tar_snake (07-24-2019), Uncle G. (07-26-2019)
  #42
Old 07-24-2019, 07:37 AM
DaveE's Avatar
DaveE
DaveE is offline
Received 1,035 Likes on 879 Posts
When I bought my street bob one of the screws had the head busted off. When I took the derby cover off the rest of it spun right out using my fingers.
  #43
Old 07-24-2019, 07:57 AM
tar_snake's Avatar
tar_snake
tar_snake is offline
Received 1,043 Likes on 494 Posts
Plain and simple - the guy who put them in put them in too tightly. They're designed to lock *without* loctite or any other stuff. It's why the *SERVICE MANUAL* says to only torque to 40-70 *INCH POUNDS*, or, let your one-year old kid turn the torx driver and done! People who have problems with these bolts like this are those who think they know better than the manual and the spec's it says to use. In the OP's case, the twit who had the bike before him screwed things up.
  #44
Old 07-24-2019, 08:21 AM
cprhed's Avatar
cprhed
cprhed is offline
Received 1,091 Likes on 630 Posts
Well you are partially correct. That twit, was me. I changed the oil last time. So I am certain I was the one guilty of overtightening them. No loctite here. But no anti-seize either. Honestly I would never have thought to use anti on these bolts. Spark plugs, exhaust bolts, sure. But on a cover like this. No.
Oh well from the sounds of it from others that have had this problem it is the head/washer that is seized and not the threads. Will look better with Chrome allen bolts anyway.
And I believe this time I will dig out the in/lb torgue
  #45
Old 07-24-2019, 03:51 PM
Death Valley Ultra's Avatar
Death Valley Ultra
Death Valley Ultra is offline
Hmmm how many hundreds of phillips head screws have I drilled out since birth. In a weird way I enjoy it. I relish the moment the head breaks off onto the drill bit like a wedding ring. BTW I like Torx.
  #46
Old 07-25-2019, 04:33 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 14,320 Likes on 6,129 Posts
Whats weird is the way you described it like a ring put a little smile on my face for some reason.
  #47
Old 07-25-2019, 10:49 AM
Carlos G Godfrog's Avatar
Carlos G Godfrog
Carlos G Godfrog is offline
Do the derby cover holes go all the way through ? If so, screw a bolt in from the opposite side with red Lock-tite, and the attach the cover with chrome acorns and washer if needed. Now you have a steel bolt and nut that can be replaced if needed.
  #48
JekyllnHyde's Avatar
JekyllnHyde
JekyllnHyde is offline
A few whacks with a rubber mallet usually helps loosens them up a bit. And you have to go at it slow while putting pressure on your wrench until they break loose. I use a 1/4" ratchet so I can use my palm to apply pressure. A palm ratchet wrench would work well too.
Death Valley Ultra (07-25-2019)
  #49
Old 07-25-2019, 01:53 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 15,161 Likes on 6,705 Posts
My neighbor tightened his so much, and unevenly, that he actually warped the derby cover.
I got it off for him, but the cover wouldn't seal after that. Lucky for him, I had a spare I gave him. but I made sure I put it on.
  #50
Old 07-25-2019, 05:31 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,817 Likes on 3,171 Posts
Originally Posted by Greezey Rider
How?
Happy to oblige:
https://www.assemblymag.com/articles...for-automation
Quick Reply: Grrr, primary derby cover bolts
