Power Vision From Fuel Moto
This is intended for those who have bought a pre-programmed PV from Fuel Moto. How reliable would you say their pre-program is? I sent them a list of the performance parts I have installed so they could program my PV beforehand. It's now uploaded into my bike however I haven't noticed a huge difference in the way it rides. Throttle response is a little noticeable but nothing worth mentioning and the backfiring from my exhaust has decreased quite a bit. I guess I was expecting a little more pull than I'm getting. What options can do you guys think I have? Calling Jamie for a better map? Getting it Dyno'd?
Fuelmoto base maps are pretty dang good, but will never give you the same result as a good dyno tune. However for a simple stage 1 and most stage 2s, their maps are more than enough to get your bike running good. For the best results, you should put that powervision to work and run a few autotunes.
The following 6 users liked this post by MTBIG G:
1 2 many (07-16-2019),
crazytown (07-17-2019),
cruisn (07-16-2019),
FNGonaRK (07-16-2019),
Luis Caruso (07-17-2019),
and 1 others liked this post.
MTBIG G (07-16-2019)
my fuel moto base map after cams started good, ran good, i had no popping on decel or anything but i could feel flat spots
they sent me a second map which was worse, started hard, and idled rough, so reinstalled the first one i will say they were more than willing to continue helpling me and may have got it perfect, but i chose to have it dyno'd the results of the dyno were night and day different, runs perfect no flat spots just grab a gear and hold on
