Horrible sound at start up. Starter or battery?
curious what you try and what fixes the problem. What doesn't make sense to me is how a new battery fixes this, even though i put a new battery in and it did fix it for me.
My thoughts are you would think this issue would not occur once the MC engine was warm and at the next gas station or stop. I would think the biggest draw on the battery would happen first thing in the morning when you go to start it (when its cold). I have never had that issue when its cold, only once the bike is warmed up. So what would that have to do with the battery? Like i said though, getting a new battery did fix this (although it does happen once in a great while still).
I've been doing the bump the starter thing the last couple of days and so far it has worked. I'm going to order a new battery off Amazon and see what that does. If that don't cure it I guess its time to rebuild the starter.
5wheels (06-24-2019)
I just replaced the battery on my 4 year old TG It wasn't making horrible noises but was starting to drag and didn't sound good. I put a V-Twin battery with 500 cca. I hadn't realized the old battery was till I put the new one in. Try the battery, you need one anyway. If that doesn't help take the next step.
If it is the orginal battery from 2009, sure go ahead replace for the hell of it. But it didn't charge itself just sitting there. Maybe decompressed on first attempt. On engine I modified before going to bigger starter, I would give a quick tap to starter to compress, I think it helped.
From your first thread I am not convinced battery. You could go for ride, and when you get home put meter on it. I believe it will be over 12.7 when you first turn it off. Wait 10 minites, put meter on it, see what it is and try to start.
What I find interesting is it starts 10 minutes later. I get a grind once in awhile on my other bike for last couple years. Sometimes after it has been charged, sometimes after not being rode much, sometimes, after being rode. Now might be battery, but it has been going on for atleast 2 years. Would think would have failed by now. Last week, after not a lot of riding it did it. I ordered starter clutch. Not positive it is that. But it has 60k on it so doesn't hurt. But hasn't done it since, so hope I install before it dies.
I get around 7 years out of batteries, but it is not hot here. Not sure where are at. I never use tenders to maintain. If your battery is old, doesn't hurt, but not 100% convinced.
I get 7 and no tender. Once middle of winter, and night before 1st ride, so not stressing the battery. If you ride the bike shouldn't be an issue. I think about it a little in fall and spring when periods are stretched out. But if you do more than short rides not so bad. Though again could be stressing. Though for me so far so good.
Batteries have come a long way. I got two lead acid batteries that are 8 and 7 years old. Not sure if they really did anything to improve those, maybe charging systems are to credit. Look autos, you might get 8-10 years, if not in a hot climate.
Any which way after 7 +/- tears a battery isn't a bad idea. But I think your grinding issue is the starter clutch. Had to do mine going into this season. Having to "bump" the starter is a pretty common tell tale that its on its way out from what I've heard. But mine didn't need bumping. It just plain went and the starter would stay engaged and make a serious racket. Starter motor is still working fine. The Starter clutch is the known weak link in the system. 25$ and an hours work and its good as new. Beats the hell out of 250-300 bucks and 45 minutes of work.
