I have a 2015 Dyna street bob. The rear right turn signal will not screw on anymore. Does anyone know how to fix it instead of buying a whole new housing?
Sounds like either the bolt is stripped or the threads in the signal are stripped. Maybe both. If it's the signal you're going to have to get a new one. I see them on ebay occasionally.
I took a closer look at the rear right turn signal. It seems like the threading to the housing unit are stripped. The bolt is fine. Would anyone happen to know where I could get a replacement? I checked on Harley and it’s $200 for the kit no individual housings
Can you run a tap down it to clean up the threads?
