Interesting Security Issue....
So, I have a 2014 Street Glide Special, my garage door is at the top of a hill, in the morning I tend to coast out of the garage, down a hill and when I am about 25 yards from the garage door I start the bike and head to work. This keeps the noise a little lower for the neighbors at 6:00am in the morning.
Twice in the last couple weeks I left the garage without the fob, coasted out of the garage and onto the street, and started up the bike without any issue. Seems strange that the bike would start without the fob. Looks like you could jump start a bike without the fob. Just an interesting piece of information.
I am positive. There is no alarm on the bike, just flashing lights. The the fob is hanging on the wall when I start the bike out of the garage, so it may be close enough to have a “lasting effect”.
when you coast out of the garage, do you already have your ignition on? if you do, then you've deactivated the security and it won't activate again until you turn the ignition off. without the fob being in range when you turn on the ignition, you are not going to be able to start the bike. and no, you wouldn't be able to jump it either. and there is no 'lasting' effect. you are either close enough to disarm the security when you turn on the ignition or you aren't.
course, there is the slim possibility that your dealer never activated your security.
The following 2 users liked this post by skratch:
Campy Roadie (05-09-2019),
RollaMo (05-09-2019)
The following 2 users liked this post by GalvTexGuy:
e6fmf (05-09-2019),
Long lonesome highwayman (05-09-2019)
If the FOB is hanging in the garage near the bike I think you also risk running down the FOB battery as it is constantly replying to the bike's signal (or vice versa, I'm not sure which way it works), but I believe the owner's manual says it's better to store the FOB more than 20 feet from the bike for that reason.
A simple way to stop forgetting the FOB is to lock your fork lock, then you couldn't move the bike very far without using the key attached to the FOB to unlock the fork lock.
The FOB on the wall is satisfying the security, if you turn the ignition on in its presence.
This is it. When I am coming out of the garage I turn the ignition on to close the garage door and I am close to the fob.
At least this has given me practice starting the bike with the code!
mazz (05-10-2019)
