S&S Compression Release alternatives?
So here’s the problem, I want to run a set of S&S superstock heads on my bike. I don’t want the easy start cams. You cannot use Harley Davidson compression releases on their heads. In order to run S&S compression releases you have to buy their rocker boxes and their compression release set up which total is going to run you about $1500 which is more than the price of the heads. They used to make their own manual compression releases, which would fit under stock rocker boxes, But now they are nowhere to be found online and if you could get them they are over $500 which seems like a scam considering any other manual releases online are about $20. I understand that there’s probably many other better options for heads, I just want to know if there’s a solution to this particular problem. Any help would be appreciated.
Compression Releases
Yeah, you can get really cheap releases on Ebay. I wouldn't waste my money on them. I have the HD manual releases in the HTCC heads on my Dyna and they were about $90.00 when I bought them about 10 years ago , but it sounds like a moot point if you want to run those heads then you are limited to what S & S wants to sell you. Harley doesn't make the heads I have anymore, I don't think, but they have some good ones never the less. Mine came already drilled for the releases so it was easy to set things up
FuelMoto is great. If I wanna as going with a more wild bigger build I would get their Outlaw Heads. A related question if I run these 79cc heads and keep my bike a 96” with. 9.8:1 compression ratio, would I even need the releases?
