Seat Rub Strips
OP, I have heard that you can put the stock seat back on without issue. Although, I have not tried it.
When I took my stock seat off, there were already marks on the fender from the previous owner. I do not know if he had another seat on there at one point, or how the marks got there, but they're there. But not too bad that they wont buff out, I think. I see no harm in leaving the strips on permanently if you can get over the look. Otherwise, get a fender bib.
You can also use 3M material in the area instead of the strips. My Heritage came with it and it is nearly invisible. I also put some on my hard bags because i kept hitting them with the boots every time I mounted or dismounted. The material is almost invisible and works very well at preventing scuffs or scratches.
They are on all the CVOs with the 2 piece seat, direct from Harley. They can be purchased separately from Harley as well. They are there to protect the rear fender from the pillion rubbing and causing damage. I put them on my RKS as well because I bought a CVO setup. They work well.
