Thank goodness I had a rubber band
RE: Thank goodness I had a rubber band
Don't forget the vise grips! You can clamp 'em to your shift shaft and get home. They work better than a Buck knife when a cable breaks! If you have ever had to ride around on an old sled, you get in the habit of carrying some basic tools. Been there, done that.
ORIGINAL: smudge
ORIGINAL: BG Weasel
They can also be an emergency clutch lever in a pinch, too. I don't carry a lot of stuff because it's easy to end up with a saddlebag full of tools, but I always carry fuses, utility wire, vise grips, duct tape (I found some wound on a flat "roll" instead of round to save space), lots of zip ties, tire plugs & CO2 cartridges, a siphon hose and some jumper cables made out of an old electrical cord.
ORIGINAL: smudge
