Lifting Bike
Old 03-27-2019, 09:47 PM
Malazan's Avatar
Malazan
Malazan is offline
Default Lifting Bike
This might be a stupid question, but I’ve never had to lift a bike before,
I'm about to do a Cam swap and I’ll need the rear wheel off the ground. I do not have access to a motorcycle lift table or a wheel chock.
I do have access to a good scissor jack. Is it safe to just raise rear wheel off ground using scissor jack even with out the wheel chock?
Or do I need to make something to chock front wheel.
Old 03-27-2019, 10:03 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
There are CHEAP jacks on Amazon that will lift the bike, like 50 dollar jacks like the type that are used on lift tables
They are rock solid because they are wide... they support quite a bit of the bike
I actually have 2 of them.... they keep my bike in Florida off the ground when I am not there.
If I were you, I'd get one, but failing that, I'd use the scissors jack just enough to get the bike supported under the frame in 2 places on some heavy duty lumber.
evotrike (03-28-2019)
Old 03-27-2019, 10:08 PM
Malazan's Avatar
Malazan
Malazan is offline
tar_snake (03-30-2019)
Old 03-27-2019, 11:10 PM
groupw's Avatar
groupw
groupw is offline
check the Denver Craigslist for 'motorcycle lift'
..... i got a lift for quite cheap, works well
Old 03-27-2019, 11:20 PM
Neggy ZRXOA 5248
I have one of these:
Amazon Amazon
and one of these... which is my primary jack
Amazon Amazon
Old 03-27-2019, 11:29 PM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 3,154 Likes on 1,861 Posts
To answer your question, is it safe? I'd say, there are safer ways (like using two scissor jacks to lift entire bike), however, you are only lifting it 2 inches... As long as you use proper precautions, it will be fine. There's so much weight up front, I wouldn't be concerned. You can always put the front wheel against a wall, clamp the front brake lever with string, put a brick in front of it, etc.
I removed the taillight assembly by using my craftsman motorcycle to lift only the rear (by sliding the jack toward the rear). Lifted the rear so I could remove the wheel to access the bolts. The bike was plenty stable.
Also, since you're only doing cam work, you shouldn't be muscling anything around, but keep in mind not to push or pull too hard and shift the balance (the same could be said even if you're using a proper jack).
Old 03-27-2019, 11:51 PM
Warrant's Avatar
Warrant
Warrant is offline
First check the rear axle, if there is a hole through it you're almost there. Get a piece of 3/8 - 1/2 round stock steel rod cut with an extra inch on either side.
Get a universal race bike stand, usually $50 or less used. Slide the steel rod through the hollow axle and lift. Good to go and safe as anything.
Works on the front or rear of the bike, if you need to remove a wheel put some jack stands under the frame and remove the race stand.
Simple, cheap and very safe....cheers!
Old 03-28-2019, 04:06 AM
assiniboine's Avatar
assiniboine
assiniboine is offline
Received 5,179 Likes on 3,140 Posts
Several DIY video on UTUBE using 2x4.
I'm not recommending them but of course they would work.
A proper m/c jack will pay for itself.
Old 03-28-2019, 04:59 AM
Hoginedgewood's Avatar
Hoginedgewood
Hoginedgewood is offline
Received 1,200 Likes on 659 Posts
Originally Posted by Malazan
i have one just like it. Ball bearings rolled away like chicklets first time I used it. Once I changed out the bearings it has been fine. Wasn't very expensive to fix.
Old 03-28-2019, 05:02 AM
RANGER73's Avatar
RANGER73
RANGER73 is online now
Received 6,339 Likes on 3,186 Posts
Bend your knees and lift with your legs.
But a scissor jack is fine.
If you can tie it off on either side with ratchet straps through
the fork trees to hold it upright would work too.
Quick Reply: Lifting Bike
