Primary Oil Color
Primary Oil Color
I have an 18 FLHX with 7500 miles. I checked the primary oil level and noticed it has a silver color to it. I have read that it is from the clutch and is normal for first 10000 miles. Is that accurate and should it be silver. Please see attachments.
Primary drain plug
Primary oil color
Primary drain plug
Primary oil color
Totally Normal
[QUOTE=Jalittlefield;18077678]I have an 18 FLHX with 7500 miles. I checked the primary oil level and noticed it has a silver color to it. I have read that it is from the clutch and is normal for first 10000 miles. Is that accurate and should it be silver. Please see attachments.
Primary drain plug
Primary oil color This is totally normal. I always change my primary oil with each oil change. Maybe overkill, but oil is cheap.
Primary drain plug
yes, changed all three holes at 1000. Change engine oil at 5000 and just changed the primary at 7500 when I noticed the silver color
