What happens if engine takes in more air than ...
If I have a choice between two styles of high flow air cleaner, which should I pick?
Here are the two choices...
https://www.harley-davidson.com/stor...18-29400246--1
or this
https://www.harley-davidson.com/stor...18-29400299--1
The first choice has less exposed filter surface area but is designed to "ram" air into the throttle body. The second choice has much more exposed filter surface areas. Which is the better filter?
The piston will push out all the air it draws in, that's a thermodynamic certainty.
If the exhaust is SO restrictive what'll happen is the piston will be slowed down more trying to overcome the exhaust pressure you'll lose power. Also, as the piston drives up on the exhaust pulse the increased exhaust pressure will force itself out the intake port as soon as that valve cracks open during the overlap, hence power lost there as well. If that's the case the next intake stroke will partially be exhaust from the last exhaust stroke and will inherently draw in less air.
Your reply actually helps me.
or this
or this
or this
or this
kickstartfan (01-26-2019)
or this
or this
Ram air? No such thing, unless you're talking forced induction. As already stated, you can't make the engine breathe any harder than it needs to in its current configuration and state of tune.
You are the first person I've seen say this, besides myself. Ram Air is a great marketing tool for the uninformed.
