purchased used FLHXS....having issues
#31
Doesn't need to be in neutral if you had the clutch pulled in.
Your bike is designed to NOT start unless the bike is in neutral, OR the clutch is pulled in OR both. Doing both takes a little load off the starter.
If you are in gear and pull the clutch the bike should still crank and start.
If you are in neutral the bike should start even if the clutch is not pulled.
................ so I immediately wondered if that was a safety feature.
RoadKingAnni562
Electrical/Lighting/Alarm
04-25-2018 02:31 PM
