HD Ion sense Ignition System
Old 01-03-2019, 11:46 PM
abhibary's Avatar
abhibary
abhibary is offline
2nd Gear
Default HD Ion sense Ignition System
Hello Everyone
Has anyone any idea, which model of HD uses Delphi ion sense ignition system to monitor in-cylinder knock ?
Old 01-04-2019, 12:19 AM
RK4ME's Avatar
RK4ME
RK4ME is online now
Received 2,325 Likes on 1,451 Posts
I believe all the Delphi EFI equipped bikes have it. My '04 Road King does.
abhibary (01-04-2019)
Old 01-04-2019, 12:21 AM
mmesa005's Avatar
mmesa005
mmesa005 is offline
The first bikes started using Delphi EFI with Ion sense in 2001. https://www.theautochannel.com/news/...ess021552.html
M8's use a newer knock detection system https://www.cycleworld.com/harley-da...-engine#page-8
Old 01-07-2019, 10:11 PM
abhibary's Avatar
abhibary
abhibary is offline
2nd Gear
Hello
Am not getting the delphi ignition module (ECU) for road king model. The only thing am getting on net is the dual pack single fire delphi ignition coil. But i need the delphi controller for ion sense. Could you just help me out by giving some link to delphi controller where i can directly purchase the one.
I am getting some dynatech ignition kit for HD. I believe this is not the same as delphi
Old 01-08-2019, 06:03 AM
shanneba's Avatar
shanneba
shanneba is offline
The ION sense is built into the coil secondary.
http://bmwmotorcycletech.info/ioniza...-susbystem.pdf
If you look at the electrical diagram you should see a connection (or two) to the ECM for ION sense.
You can find the electrical diagrams online at https://serviceinfo.harley-davidson....cle/lookupForm
Old 01-08-2019, 07:26 AM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,575 Likes on 1,969 Posts
A few weeks back someone posted this link about EFI. Go to slide 35 and it explains ION Sensing.
https://www.dropbox.com/s/hfa9a1yhfx...asics.pdf?dl=0
Old 01-08-2019, 11:13 AM
RK4ME's Avatar
RK4ME
RK4ME is online now
Originally Posted by abhibary
Hello
All I can do is Google it; you can do the same. Good luck with your bike.
Strannix
08-03-2017 10:03 AM
rouskie
Ironhead
03-20-2017 10:14 PM
Poacher1967
Shovelhead
13
09-24-2015 07:07 AM
03sbra4
12-09-2013 01:18 PM
ssls6
12-14-2008 10:13 AM
Quick Reply: HD Ion sense Ignition System
