Removing welded in baffles
Can anyone give me some tips on how to surgically remove the baffles from a set of Samson Fishtails? These are not the simple remove the screw and slide the baffle out kind. There is an inlet sleeve (seems to fixed really well) and a small spot weld on each end of the baffle. I’ve tried to send them back for removal and they are saying it’s not possible but it seems like it should be. I saw in an older thread someone was able to do this job. Thanks!
Received 6,056 Likes
https://www.hdforums.com/forum/gener...tomy-easy.html
Once it is cut, it would be easy to cut the ring that has the spot welds in small chunks until you "cleaned" off the ring from the tip.
