Jiffy stand hangs a bit low/loose - adjust/replace?
Old 01-17-2013, 08:41 PM
HD7585's Avatar
HD7585
HD7585 is offline
Some I've read bend the spring......insert pennies between the coils(makes spring longer)....install and remove pennies
Old 01-18-2013, 01:04 AM
Poolie's Avatar
Poolie
Poolie is offline
Agree it's probably the spring. I've replaced mine twice after coming off a curb. Easy job, chock the bike up with a couple of bricks or lump of timber' remove jiffy stand bolt, old spring off, new spring on, jiffy stand down, unchock, done. About 10 mins work.
I bought three springs and keep a spare on the bike just in case...
Old 01-18-2013, 06:08 AM
skratch's Avatar
skratch
skratch is offline
Received 4,371 Likes on 2,543 Posts
you guys are doing it the hard way. to replace the spring, take off the bolt on the locking tab, swing the kickstand forward, replace the spring, swing it back, replace the locking tab and bolt. no pennies needed, no yanking with pliers, no popping yourself in the nose. easy, peasy
Old 01-09-2014, 09:19 AM
clodhopper's Avatar
clodhopper
clodhopper is offline
6th Gear
I tried that. When I swung the stand forward it moved the spring tab further away from the spring tab on the frame.
So then I tried the penny/washer spring and all I did was to sprung the spring.
I got two springs coming in the mail today. Hopefully can get it done today.
Old 01-09-2014, 10:07 AM
Sharkman73's Avatar
Sharkman73
Sharkman73 is offline
Holy thread resurrection! OP was July of '07!
Old 01-09-2014, 02:52 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,075 Likes on 2,558 Posts
I saw that too. I wonder if he fixed it in the last 7 years?
dshelly
08-17-2016 07:04 AM
Mac daddy 103
06-15-2016 04:44 AM
Sliver1
03-31-2014 05:29 AM
DiggerG
06-26-2012 04:47 PM
tmitchellof PG
04-21-2008 06:28 PM
Quick Reply: Jiffy stand hangs a bit low/loose - adjust/replace?
