Harley problems
Old 08-13-2018 | 11:34 AM
Dirty Harry's Avatar
Dirty Harry
Originally Posted by sag3435@gmail.com
Just so everyone knows I have no rode it since I felt the vibration I'm not a idiot lol
No one thinks you are an idiot.....but you do sound a little clueless as what the next step should be or where to start...so maybe start by draining the primary and inspecting the oil...if you have a repair manual read it before you pull the outer cover and check the adjuster...look at the chain and sprockets ,check the clutch housing and internal components inside and out of the basket...Pull an inspection of the stator assembly ....next step is to pull the transmission and inspect the bearings, shafts an gears.... once you have all the components out of the primary and transmission apart and still don't know what to do next .....take it to a trusted repair shop with all your stuff. Or before you go through a lot of effort that might not get you any closer to finding your problems...take it to a trusted repair shop. If I didn't know how to do any of the above and did not have a repair manual, I would take it to a trusted repair shop...Good luck and Let us know what you find !!!
Old 08-13-2018 | 11:42 AM
sag3435@gmail.com's Avatar
sag3435@gmail.com
2nd Gear
I'm probably just gonna take it in how much do you think it would run me if they had to do all of that at a HD shop ?? Juat so I know what I'm looking at spending
Old 08-13-2018 | 12:07 PM
Redoilokie's Avatar
Redoilokie
I'd plan on 100-200 for diag, and the total repair bill would depend on what's wrong
Old 08-13-2018 | 12:18 PM
Dirty Harry
I'm probably just gonna take it in how much do you think it would run me if they had to do all of that at a HD shop ?? Just so I know what I'm looking at spending
It might be worth a phone call to a shop and explain what the issues are....let them hear from you and maybe they have an idea !!!
Old 08-13-2018 | 12:24 PM
sag3435@gmail.com
2nd Gear
Thanks I'll let you guys know what I found out
Old 08-13-2018 | 12:32 PM
hardheaded's Avatar
hardheaded
Maybe the primary chain adjuster has failed to ratchet up and the chain is running loose.
Old 08-13-2018 | 04:48 PM
nytryder's Avatar
nytryder
Also check the condition and tension of drive belt and sprockets.
Old 08-17-2018 | 11:27 AM
Super Glidester's Avatar
Super Glidester
Aww C'mon now ... Harleys don't have "Problems".....
sirrat007
2014-2023 Touring Models
26
07-27-2017 03:50 PM
is6267
09-18-2009 07:24 AM
fjm3rd
09-14-2009 10:50 PM
sbergloff
06-05-2008 12:25 PM
Leester
05-12-2008 10:09 PM
Quick Reply: Harley problems
