Melted plastic on exhaust
07-23-2018, 06:22 AM
Bought a Frog Tog rain suit and finally had to use it yesterday while riding through Ohio. I know, it's a cheapo and made of plastic. Of course I melted a hole in the right leg. This left crap on the exhaust pipe. Any advise on removing it and restoring the chrome finish before I start?
07-23-2018, 06:24 AM
0000 Steel wool and WD-40 Heat the pipe up, soak the steel wool in WD-40. This will take it right off without scratching the chrome
07-23-2018, 06:33 AM
Heat exhaust up and use wet rag to wipe plastic off.
07-23-2018, 06:35 AM
She's shot...time for that exhaust upgrade.
JK, in addition to above recommendations, you can take a butter knife and gently scrape away the thick stuff, but sometimes bug/tar remover will get most of the goop. Good luck.
07-23-2018, 07:21 AM
Heat the pipe up, spray oven cleaner on a clean rag and wipe the stuff off the pipe.
I've had to do this a couple of time, seems to work very well.
07-23-2018, 08:01 AM
Nothing works best than carburetor cleaner and a rag. Comes off like nothing. Make sure the pipes are cold.
07-23-2018, 08:09 AM
Best of luck but this does make me laugh about all the people that use frog togs. Too bad the title of the thread can't be renamed.
07-23-2018, 08:18 AM
Quote:
Originally Posted by
Spikehorn
This works good and does not scratch the chrome.
07-23-2018, 08:19 AM
nobodyknowsme
At least frogs togs is better than wearing the time tested leaf bag rain suit.
07-23-2018, 11:55 AM
WD 40 and a razor blade. Frogg Togg goo comes right off. Don't ask me how I know .....
