Fork oil leak?
Fork oil leak?
Today I decide to go for a short ride and just riding along and just happened to look down and noticed oil oozing out the very top of the tripple tree on the left fork side around the bolt. I had a chrome frontend installed this past winter by the dealer. Could that bolt just need to be tightened to spec? Or something better left alone by me? As I have told you guys before I'm no tech but certainly not afraid to turn a wrench on something simple. My whole thing is I have no idea what that bolt tightens and how bad I can make something worse by messing with it
i doubt that enough oil has 'oozed' out to make a significant difference in the level between the two fork tubes. having had the work done over 6 months ago, the dealer is probably not going to be very forthcoming. you can tighten the top fork bolt down yourself. keep an eye on it, and if it still leaks even after you've tightened it, then i would attempt some sort of warranty claim against the work that they performed.
